We still have a bunch of the 16x16 P10 RGBpixel panels…
Here are a few projects that you can do with them:
We have a fair pile of tested (marked OK on back) and working 16x16 RGB LED panels available for projects… These are in a box in the LED rack (next to Ecycling shelf). The cost for each panel is $5.00
You can either drop cash off in the donation drop box or eTransfer to the Space…
[image]
We also have a smaller pile of defective ones (marked BAD on back) in the Ecycling/UpForGrabs area should you want to try resituating them…
[image]
In order to make use of them you will need the following: …
https://vimeo.com/622019469
This a nice kinda artsy project that runs through a bunch of effects sequences on a VHS RGB Panel…
It is based on the Aura demo (fram the FastLED library) that cycles through a bunch of effects
You can either drop cash off in the donation drop box or eTransfer to the…
https://vimeo.com/625101539
Here is another project for the VHS RGB LED panels. This is a digital clock with Tetris style animations each time the digits change (every minute). It gets it’s time via a Internet time sync (NTP) so it needs a Wi-Fi connection but at least it will always be accurate.
In order to make a VHS Pixel Panel you will need the following:
VHS RGB LED Panel (2 of them)
Short LED Panel Jumper (in same box as LED panels)
ESP8266 Module (NodeMCU, WeMOS, etc)
Female to Female…
Amaze your friends…
Be the first on your block to have a Tetris Clock…
I was thinking of taking a whole bunch for an art project if no takers
I somehow never noticed these. If there’s still any left next time I’m at the space I’ll grab a couple.
How many are you looking to get? I am doing an art installation next month, and want a whole bunch. i can return them to the box afterwards
@xquared - what are you gonna do with the displays? i love art installations…
I’d be happy even with one, and if you’re returning some I don’t mind waiting either.
I suck at self promotion but i am going to be at this event tomorrow
@xquared - Please takes pics and videos of your installation!! I’d love to see it but stuck in covid isolation…
There was some technical issue, I ended up not able to do the live installation.
I returned the four panels I borrowed back into the box already.
I did manage to get the 1/4 scan aurora demo to work across more than one panel.
I also managed to get it working with Blynk
system
Closed
May 16, 2023, 11:55pm
10
