Adopt a woodworking project
#1
I’ve designed and laser-cut wall planters a fairly long time ago :
They are made of stacked plywood (6mm), and were designed as 5 sizes nested into 1 file (to save wood).
I built 3 of them, and waterproofed 2 of them with an expensive and stinky epoxy sealer that wasn’t very successful at keeping the wood waterproof, and the planters ended up slowly rotting when watered.
The third one was a gift to a friend, who has been told to keep it dry (no live plants :frowning: ).
I have the parts ready for the 2 last ones, and I’m not sure I’ll use them. They’re taking up storage space at VHS because I don’t want to dump them.
Is anyone interested in taking over? I’d be happier if they were used than just building up a dust patina…
( I still have some of that epoxy sealer, and while my 3 coats were not enough, more coats could do the trick. The epoxy could be part of the adoption)
#2
These are gorgeous!
We would love to adopt them with the Epoxy and if you can show your expoxying tips, the even better!
Please sign them with your name, Thanks!
#3
I’m not sure I’ve been very clear : what I have left is the parts to build 2 of those. It means you need to glue and grind them to get the final result, as in this post
That’s a lot of work, noise, and sawdust.
Let me know if you’re still interested
#4
That’s quite a bit of heavy lifting! I will pass on it considering “Some Assembly Required” task!
#5
If someone wants to take this on, they are more than welcome to enter it into the woodscrap challenge:
#6
Resuscitating this thread, this laser cut project is still up for grabs. There’s parts for 2 or 3 pieces, I’m not sure.
Give it a chance, it’s going to get dumped otherwise!
Finished pieces will be just over 1 foot high, FYI…
#7
If no-one else wants this I’d love try to reuse these in another project.
#8
I had a look at these today. While they look great I am going to pass on this as I’ve got too many other projects on the go.
Some photos for anyone else who might be interested in taking these.
#9
@baptiste I’ll take it.
Thanks
#10
Completely missed this reply. Go ahead if you haven’t already!
