#The100DayProject
Day 14
https://instagram.com/p/2SmS2hA5YK/?taken-by=funvill
Follow me on instagram
This is a test of different polyhedron shapes. I’m planning on making twelve different shapes. Then cutting patterns into the faces of these shapes and adding LEDs to make lanterns. (similar to the panels for the dome project above). Then hang them all like a chandler or mobile. Eventually these will be made out of laser cut wood.
This shape is a trapezohedron
Source files
#trapezohedron #geometry #3d #laser #lasercutter #paper #papercut #symmetry #polyhedron
Day 15
https://instagram.com/p/2gyWfug5Vh/?taken-by=funvill
This is a test cut of a panel for the pocket universe project. Each hole is the size of a arcade button. I like it but I want change half of them to LEDs so when you press a button it changes a color of LED on the same panel. Still thinking about this.
Day 16
https://instagram.com/p/2g0FYHg5av/?taken-by=funvill
A test panel for the pocket universe project. I like this one.
Day 17
https://instagram.com/p/2gzGIJA5Xv/?taken-by=funvill
A test cut panel for the pocket universe project. I like this one but I expect it to be to complex for the shotbot. I will have to redesign this one.
Day 18
https://instagram.com/p/2gzNBFA5YG/?taken-by=funvill
A failed test cut panel for the pocket universe project. This one is too flimsily to work. Rejected.
Day 19
https://instagram.com/p/2gzti1g5Zw/?taken-by=funvill
A failed design for the pocket universe project. I was trying to see if a maze would work for one of the panels. The problem is that the maze paths are only connected to the size at one point. It becomes to flimsy and would probably break.
Day 20
https://instagram.com/p/2h7d9Jg5Tl/?taken-by=funvill
Got the LEDs and the brains working in the Untztrument trellis midi kit I from Adafruit and started in day 4. It works! This thing is a lot of fun to play with.
Day 21
https://instagram.com/p/2iUnUdg5bv/?taken-by=funvill
Got the Arcade button midi control from day 3 wired up and working. This makes a lot of noise when pressing the buttons but its FUN and you can really hammer on the buttons without breaking anything. 4 hours of crimping, soldering, coding, mapping, debugging. Arcade button midi controller with a teensy.
Day 22
https://instagram.com/p/2pw8beA5VH/?taken-by=funvill
Another test cut for the for the Pocket Universe panels. Made in wood with VHS’s laser cutter. I like this one a lot and it definitely made the cut. This design was done for this project by @Adam_Barlev
Day 23
https://instagram.com/p/2pxKovg5VX/?taken-by=funvill
Another test cut of panels for the Pocket Universe project. This one is done in paper because I ran out of wood. This design was done for this project by @Adam_Barlev. Thank you !
Day 24
https://instagram.com/p/2pxxEfA5V-/?taken-by=funvill
Another test cut for the fairy door NSG project. I like this design over the ones that I made in day 9. It still needs more work but its getting there.
Day 25
https://instagram.com/p/2saM1Kg5UC/?taken-by=funvill
A business card that I was working on an abandoned as it fine print on the “print print” sponsorship from Maker Faire and found it to be unreasonable. Sigh…
Day 26
https://instagram.com/p/2uWxapg5an/?taken-by=funvill
Kit build day, I made a L3D cube. Quick easy build and the dome is fun to play with.
Day 27
Video
https://instagram.com/p/3FWDAoA5VN/?taken-by=funvill
Picture in triangle
https://instagram.com/p/3FkLcag5d1/?taken-by=funvill
Spent the entire day at Maker Labs running in to constant problems with (My designs) but gone the first panel cut. I have a lot of updates to do to my other designs before I go back and cut the rest. Some of the detailed sections of this panel could not be cut with the router bit that I selected.
Day 28
https://instagram.com/p/3Il_E4A5UE/?taken-by=funvill
Second panel for the pocket universe Dome project. I like this one a lot.
Day 29
https://instagram.com/p/3ImNIuA5UO/?taken-by=funvill
This panel is like a picture frame, the hole in the center will be filled with a laser cut design.
Day 30
https://instagram.com/p/3ImeBcA5Uh/?taken-by=funvill
Large picture frame style panel. I don’t like this one as much as I like the smaller one from day 29.
Day 31
Full size
https://instagram.com/p/3Keg4GA5U_/?taken-by=funvill
Close up
https://instagram.com/p/3Keu78A5VV/?taken-by=funvill
A massive 70cm laser cut of branches. This will be one of the centers of the “frame” style panels from day 30. This took a lot longer then I thought it would but looks great! .
Day 32
https://instagram.com/p/3KfRxPA5V8/?taken-by=funvill
A very quick thank you card for a friend’s wedding. 8 mins to design, 45 secs to cut.
Day 33
https://instagram.com/p/3Kgkw8A5X7/?taken-by=funvill
A test of one of the designs for Fairy Door workshop. I have a moderate to extreme dislike for sparkles. This is from the template created in day 24
