I have a few parts (<$20) I need. I don’t care which distributor I get them from. So, if you have some parts you would like to add or have an order you can add my parts to, let me know. Ideally I would like to make the order early next week.
If you are using Newark lemme know as I have a $20 order for some items that only they have.
@packetbob What are you looking for? Newark does not have either of the parts I want…
I’m looking for:
Coaxial D-Sub Mixed Contact | Solder Cup | 682M Series | NorComp (11w1 size, P/N 682M11W1203L001 )
http://www.te.com/usa-en/product-1981568-1.html (micro-USB … I’m stuck with a weird footprint on the PCB I bought)
I need some IBGTs that only Newark seems to sell in small amounts…
DigiKey has a 300 unit min for some reason…
But I do have few things I can get at DigiKey should you end up going there…
I have a few things I “need” too.
Man I hate microusb connectors, so so so many footprints. Mini has like two of them.
What do you mean? They’re standardized, right? ducks and runs away as fast
as he can
Actually the IGBTs I need are only available at Mouser rather than Newark…
Not sure if that helps you @hectorh…
I also have a list for Digikey…
@packetbob Are the IGBTs you need for the TinyTesla? FGA60N65? Digikey has them in singles for $8.38 in stock. Do you also need the rectifier? (It’s included in the official IGBT replacement pack)
@TomKeddie What are you looking for?
Hey Hector,
Just these two
100 x 1276-6353-1-ND (0603 ferrite doesn’t have to be this one)
50 x 952-1478-1-ND (SMD test point of reasonable size)
about $20 worth, could come from Mouser too.
Cheers,
Tom
Hey @hectorh
The part I need is the IRGB4620DPBF. DigiKey only has them in lots of 200 while Mouser has them available singly… The FGA60N65 is for the larger OneTesla
But let me know where you need to order from and I’m sure i will find something to get…
I’ll order from Mouser, they have my micro USB, Bob’s IBGTs, and the test points for Tom.
@packetbob How many IGBTs do you want? Anything else you want to put in the order?
@TomKeddie They don’t have the exact specs on the ferrite beads ( 0603, 6A, 30ohms @100Mhz, 10mOhms DC), but they do have close ones. Do you want to take a look through their catalogue see if there is anything that would work?
@hectorh
Here is what I want from Mouser:
4 x http://ca.mouser.com/ProductDetail/Aavid-Thermalloy/53-77-4G/?qs=sGAEpiMZZMs1yZizLLgjI8MLTWiiyyMs
Thanks for going to all that trouble, 875-HI0603P600R-10 is fine, the specs are very rough.
I’ll also get 2 x 774-745C101331JP resistor packs please.
so, in summary, with thanks.
100 x 875-HI0603P600R-10
10 x 855-S1751-46R (down from 50).
Thanks! … Last call, I’ll be making this order on Monday
Also
2 x 538-87760-1416
Tom, Bob, here is the link to the saved cart as it is right now:
I wanted to stock up on some generic parts. Can either of you recommend some general purpose transistors (NPN, PNP) and FETs to add to my parts library? SMT, thanks! and any other active SMT components that are used frequently (I have none, only passives).
I recommend a stock of MMBT3904 and MMBT3906
Makermobile Simon suggested these BJT parts some time back, I’ve used them in a number of designs.
771-PBSS4021NT215
771-PBSS4021PT215
FETs are not my strong point.
Link doesn’t work for me. BTW are you planning to use the $20 fast or $8 slow shipping?
Typo in the URL, try again please
