This coming Wednesday I’ll be running a laser cutter orientation for 4 members, reply here to reserve your spot!
The cost is a $30 donation to the space, and before you arrive, read through the laser operation manual to familiarize yourself with the fundamentals: https://vanhack.ca/doku.php?id=tool:laser_cutter:operation_manual
yeungx
2
If it is not too greedy, may i hold 2 spots for hazel and I. If there is a lot of other people that want in, I can only take one spot for now.
Thanks for putting this on.
No problem, I’ll be hosting these much more frequently over the next while to get everyone trained up.
One spot left!
Arrgh
5
I believe Hazel isn’t a member? The training is up to Tristan, but they won’t be able to actually use the laser unless they join.
yeungx
6
Got it. We will be sure to respect that.
Awesome, see you on Wednesday
The space for this training is now full, keep your eye out for the next one in a couple weeks!
Do you mind if I stop by Wednesday as well, in case somebody doesn’t show?
Thanks!
Kyle
Sure, and even if everyone shows I’m sure we can manage the extra space, see you tomorrow
Markus
11
Hi, I would be interested in the net laser cutter orientation.
Hi Markus,
I’ve just posted the next orientation for Monday the 30th, check it out here.
system
Closed
14
