Laser Cutter Training - DATE CHANGED to Monday Jan.6 6pm
Coming up on Monday Jan 6, I’ll be running a laser cutter orientation for 4 members, reply here to reserve your spot!
Generally the session runs about 2.5hrs
The cost is a $30 donation to the space, and before you arrive, read through the laser operation manual to familiarize yourself with the fundamentals: https://vanhack.ca/doku.php?id=tool:laser_cutter:operation_manual
If you would like to stay after and make something cool, bring a vector file saved as a .dxf or older version .ai and perhaps we can try it out!
I’d be interested. Thanks!
Please add me to this laser cutter training session. Thank you!
Currently two spots left!
Since it seems the timing would work better after the new year, this training will now instead take place on the 6th January
I’ll go if there’s a spot
Great, see you then. One spot left
Hi there, if you increase your numbers or run another session please let me know.
Hi Pat, there’s still one spot left in this group if you would like to join on the 6th!
See you there.
