A CNC ROUTER is used for wood, unlike the two metal CNC mills that we currently have. At this point its hypothetical as we don’t have the space, infrastructure or the money to support getting a CNC router.
Size
I would like to see a 48"x96" because it fits a full size sheet of plywood 4x8’. I could see having a 48x60" (4x5’) would work too as we could cut the sheet of plywood in half with a panel saw. It would make it harder to make furniture as most of the designs are built for a full sheet of plywood.
Shopbot PRSalpha
I am very impressed with the Shopbot (PRSalpha) 96"x48" w/6" Z axis ($17,845 USD) + $500 for dust extraction + $500 for shipping and duties, + bits and mills. It uses V-Carve as the software and is the best “one button go” system I have seen so far. This is the machine that MakerLabs and Techshop choose and there is a good reason for this. Its hard to make mistakes, its even harder to damage the machine, and you can teach someone the basics of how to use the machine in about an hour. Wholly hell is it expensive! ~$19k USD all in.
X-Carve
I have heard good things about the X-Carve (from inventables) but I don’t know much about it. Has anyone had any experience with it?
Cheep ones from AliExpress
My main goal would be to have it as simple to teach as possible. We lucked out with a Chinese laser cutter mainly because we had several very experienced, knowledge and dedicated people to get the laser cutter up and running after it arrived. I would be worried about not being able to repeat the success that we had with the laser cutter.
What CNC router would you like to see at VHS? What size? What features?
