This is a review of tools currently on the Woodshop Shelves:
Bosch JS470E Jigsaw
Bosch ROS20VSC Random Orbit Sander
LED Worklight
Dremel 220 01 Workstation
Mastercraft Rotary Spin Saw (Accessories?)
Bernzomatic Propane Torch
Ideal Electric Marker
Spin Saw Accessory?
Spin Saw Accessory 2?
PowerSonic Mini Wood Lathe
King Canada Belt and Disk Sander
Jobmate 6” Bench Grinder
Sears Router Model 315.17380 (Broken)
Sears Router Model 315.17380 (Broken) Other angle
Dewalt DW364 Circular Saw
Dewalt DW364 Circular Saw (Other Angle)
Bosch GWS 600 Professional Angle Grinder, Blue
Mastercraft Plunge Router W061705 (Broken)
Empty Dremel Case
Empty Dremel Case (Open)
Skil 16” Scroll Saw Model 3330
Skil 16” Scroll Saw Model 3330 (Close up)
Mastercraft Palm Belt Sander (Broken?)
Mastercraft Palm Belt Sander (Broken, inside case)
Porter Cable Model 1001 Router Fixed Base
Porter Cable Model 1001 Router Fixed Base (Close up)
UltraJet Power WOW Pump 1011109
UltraJet Power WOW Pump 1011109 (Close up)
Mastercraft Router Table 54-6903-8
Mastercraft Router Table 54-6903-8 (Close up)
VHS Magnetic Door Lock
VHS Magnetic Door Lock (Open box)
Delta Bandsaw 56 1/8”
Delta Bandsaw 56 1/8” (Close up)
Unknown Hook-Shaped tool
Metal grid plate “Mount Plate for Lights”
Two wood pieces with yellow knobs
Makita LS1214F 12-Inch Dual Bevel Sliding Compound Miter Saw
Delta 37-190C 6" Jointer
Delta 37-190C 6" Jointer (Close up)
Power switch
Steel City Tool Works 13” Deluxe Portable Planer with Helical Head (40200H)
Steel City Tool Works 13” Deluxe Portable Planer with Helical Head (40200H) (Close up)
Mastercraft Air Compressor
Ridgid Portable VAC
Tools not owned by VHS
@Spicehammer Forge
@Spicehammer Anvil
Please review this list and mention if you know the tool listed is in good working order
The objective as always is to come to consensus in 7 days.
| Equipment | Action |
| Bosch JS470E Jigsaw | ??? |
| Bosch ROS20VSC Random Orbit Sander | ??? |
| Dremel 220 01 Workstation | ??? |
| Ideal Electric Marker | ??? |
| LED Worklight | ??? |
| Bernzomatic Propane Torch | ??? |
| PowerSonic Mini Wood Lathe | ??? |
| Mastercraft Rotary Spin Saw (Accessories?) | ??? |
| Spin Saw Accessory? | ??? |
| Spin Saw Accessory 2? | ??? |
| King Canada Belt and Disk Sander | ??? |
| Jobmate 6” Bench Grinder | ??? |
| Sears Router Model 315.17380 (Broken) | ??? |
| Dewalt DW364 Circular Saw | ??? |
| Bosch GWS 600 Professional Angle Grinder, Blue | ??? |
| Mastercraft Plunge Router W061705 (Broken) | ??? |
| Empty Dremel Case | ??? |
| Mastercraft Palm Belt Sander (Broken?) | ??? |
| Skil 16” Scroll Saw Model 3330 | ??? |
| Porter Cable Model 1001 Router Fixed Base | ??? |
| UltraJet Power WOW Pump 1011109 | ??? |
| VHS Magnetic Door Lock | ??? |
| Mastercraft Router Table 54-6903-8 | ??? |
| Unknown Hook-Shaped tool | ??? |
| Metal grid plate “Mount Plate for Lights” | ??? |
| Two wood pieces with yellow knobs | ??? |
| Makita LS1214F 12-Inch Dual Bevel Sliding Compound Miter Saw | ??? |
| Delta Bandsaw 56 1/8” | ??? |
| Power switch | ??? |
| Delta 37-190C 6" Jointer | ??? |
| Mastercraft Air Compressor | ??? |
| Steel City Tool Works 13” Deluxe Portable Planer with Helical Head (40200H) | ??? |
| Ridgid Portable VAC | ??? |
