Laser Training
for Women and Non-Binary Folks
Training usually runs for about 1.5 hour.
This training is required to be able to use the laser cutter. We will go through safety, setup, and all the things you should know to get you started on your laser cutting journey.
For my own comfort level, his event is limited to 3 students each slot and if you can wear a mask, that’ll be greatly appreciated. Don’t worry if you miss this one, we will run more training in the future. Reply to this thread to save your spot.
Bring a vector .dxf file or an .svg file and we can laser cut something after the training! Looking forward to meeting everyone and hearing about your ideas.
The cost of training is $30 which will go towards keeping the laser functional.
Completion of the training will grant access to the use of the laser cutter, and you must be a VHS member to use the laser cutter once trained.
You can drop cash in the donation box, e-Transfer to directors@vanhack.ca, or make a donation via PayPal on Membership - Vancouver Hack Space 1.
