I’ve donated a few stained glass tools to VHS.
These are:
- An 80W Weller Soldering Iron plus an extra tip. If you do use it for other electronics work please put it back with the stained glass tools
- Two spools of 60/40 solder specifically for stained glass work
- Plastic Running Pliers - with extra tips - Used to break glass once it has been scored.
- 3/8" copper tape - This goes around the edge of the glass pieces before you solder the pieces together
- A glass file for smoothing rough edges of glass after it has been cut. - This file is for glass only.
Still need a Glass Cutter. I’ll pick one up at the hardware store.
The stained glass tools
Stored in E2 box
Stored above the sewing machines
