So of course the day before I go out of town, the A/C unit dies and when I return to the office, it’s 35C in there from the equipment running with only a window fan for cooling. Not fun, turned on the intake fans to pull in cold outside air and filled the evaporative cooler and within a few hours it’s back to a much more comforable 27C. With those running overnight, it’s now 24C.
So basically it looks like the GFCI melted, as did the 3 outlet power bar and the extension cord. Luckily I caught it before it set anything on fire.
You can see pics here
http://i.imgur.com/5QmNmIj.jpg
http://i.imgur.com/fg6FFfI.jpg
http://i.imgur.com/1YVt0Vl.jpg
The GFCI unit is labelled
Tower Mfg Corp
Catalog Number 30380
15A 120VAC 1800w
http://www.towermfg.com/lcdi.htm
I’ve got a call into the parts department for Royal Sovereign to see if they have the replacement power cable with GFCI, failing that can anyone recommend where I can get a replacement locally?
I was initially thinking of just cutting the cord a few inches below the bad unit and installing a new one, assuming I can get one locally. But given how hot the unit was and the various melting effects across the various power connections, I’m thinking I likely need to either cut off 1 to 2 feet of the power cable or replace it altogether along with the GFCI.
Or should I not bother as this unit will likely still be unsafe to use? It’s been powered on and running (cycling the compressor on and off as needed) for about 5 years now. I’ve only had to replace the lower fan blade unit 2 or 3 times now and it’s otherwise just kept chugging along.
If it was warm enough that Costco had their yearly A/C unit sale (which is where I originally bought it), I’d just go buy a replacement unit as this one has definitely gotten noisier over the years. But alas that’s probably 3-4 weeks away as I was told when I called Costco. Basically nobody actually has any stock locally and it’s typically 2 weeks for shipping. Also the choices are pretty slim picking and the prices are high. I paid $350 including shipping for this 12000btu unit.
The current unit has 2 hoses and self evaporates, I would NEVER, EVER, EVER, EVER buy a portable unit that requires you to drain water from a resevoir, that’s just so 20th century
Ditto for single hose units, not so efficient.
Any comments and suggestions.
