I live fairly close to Burnaby Mountain, and I’m curious about listening in on any future fires that flare up in the area.
Does anybody know what frequencies ( and other settings ) I could use to listen in on dispatch or the tactical channels?
I’ll admit: I’m partially concerned that without cable TV I might miss some important developments regarding any local fires. Does anybody have any good resources ( Twitter feeds, websites, anything ) that can keep me up-to-date on any fires in the Lower Mainland I should be aware of?
Your best bet is via net:
http://ltr.tac9.ca:8000/
However Burnaby Fire doesn’t seem to be covered…
As far as I know most lower mainland EMS have moved over to Ecomm and use a digitally encrypted system. However quite a few fire departments rebroadcast un-encrypted but I think they still frequency hop so you need a decent scanner (and possible a PC to be able to put the parts together). I believe this is how the web site above gets its feeds…
The ScanBC twitter feed @hectorh listed is good and I would think Burnaby Fire would have their own…
The VHS radio guys probably know more (or can point out if I am incorrect)…
