Tilt the track slightly so that it closes with gravity and doesn’t require the counterweight (or requires less counterweight). This may require the purchase of a couple more hanger brackets, at $6 each (plus tax): https://www.princessauto.com/en/square-track-face-mount-bracket/product/PA0008979361. I say this because the existing ones are showing some signs of slippage, which suggests to me that more support is needed:
If we are tilting the track we may not be able to re-use the same mounting location though.
For Problem B, I propose that once the self-closing action is reliably restored, we install strip brushes at all the gaps to block dust from crossing into the main space. These come in a thousand different varieties (and prices), but here is one example made for a standard 36" door that costs $38 on Amazon. I’m sure we could do better if we shop around.
Is this something that can come out of the building improvement budget? I’m happy to order the parts if I can be reimbursed. I can help with the installation as well but handling the door is going to be a 2-3 person job so I would need help.
Edit: anyone with more door experience is also welcome to chime in
@ddq I like your plan and am interested in helping when you need it.
I would suggest planning to return the unused stuff to princess auto or only buying what we need. VHS has a lot of extra stuff hanging around, it’s unlikely we’d be able to find a spare track in the future.
Am happy to cover one of both trips to princess auto once the ice melts.
Fair point. The existing trolley may just need a good cleaning but we won’t know until we take it apart. We can easily return stuff if it turns out we don’t need it. I will have a bunch of work days in Abbotsford soon so I can stop at Princess Auto on the way back one of those days.
Also, thanks for offering to help. When are you generally available? I have some evenings and usually weekends (but not this coming weekend).
I’m available most weekends now that kids soccer has wound up. I work Mon, Tue, Thu, Fri 6:30am - 3pm so available Wednesdays and most days from 3pm. The more notice the better but I can do same day some times.
The toughest bit about this project is probably going to be moving that electronics bench to get access to the full length of the track.
@TomKeddie I picked up a new trolley set and a couple more brackets from Princess Auto today.
The next couple weeks are going to be busy for me but could we tentatively plan for the evening of March 8? I likely wouldn’t be able to get there until around 6pm.
March 15 or 16 might also work.
Clearing and moving the electronics bench is going to be quite a task, you’re right! If anyone else reading wants to help, they are more than welcome to join!
We put a laser level on the door track and discovered that it was actually travelling slightly uphill previously. We tilted the whole track so it’s now a bit downhill, to help with self-closing.
The support brackets for this type of track are supposed to be mounted every 24 inches, and it previously had about 6 feet between brackets. We added three more brackets to hopefully prevent the track from moving.
We also replaced the wheel trollies with new ones from Princess Auto that seemed to have slightly smoother bushings. This was kind of a “the old ones don’t look too bad, but we might as well replace them now since the door is already off”.
Result: the door closes a lot easier now but there are still some improvements needed.
Thank you to @myelophone and @Majicj for helping and especially to @TomKeddie for doing most of the work while the rest of us watched.
Next steps for Door Problem A:
shim the door track out from the wall a bit more to stop the door brackets rubbing on the wall (this is why it stops about half way)
install a stop for the counterweight so the door doesn’t slam so hard at the end of its travel
install a full height stop for the door that will also function as a dust seal for that one side
(maybe) install a short guide on the floor to guide the door home/stop it swinging at the end of its travel
fix the wood shop sign letters (sorry to whoever made them, we had to remove them to install the brackets)
move on to Problem B (dust sealing) once all of the above is done
Update: I tried adding a shim (separately) to each of the hanger brackets at the end of the track to eliminate the rubbing on the door frame. This just made it worse, so I took the shim out again and left the track how it was before. It seems that the way I attempted to shim the track put it on an angle which then made the wheel trolley rub on the track.
This is the spot where the door hanger bracket is rubbing:
I can have a look next time I am in, but my thoughts are that the centre of mass of the door may not be centered under the track, or there is something else that is pushing it out of alignment.
Possible fixes might be:
to add mass to one side of the door to balance it out
add some guide rollers near ground level to hold the door the proper distance out
clearance the wall with a persuader (probably a bad idea)
That might solve it. Would just have to figure out how to make the carriage bolts work or use an alternate fastener with a really low profile head, like maybe a stove bolt or a flat head socket cap screw.
