In my bedroom I have an X10 lamp module that I’ve been using for at least 10 years, it works. I have a multi button remote control for controlling the other lights in the bedroom via X10.
Until yesterday I had a dimmable CFL installed, it worked, of course it buzzed as you dimmed it, but that’s expected from the cheap/basic X10 lamp modules, will likely replace it with an Insteon unit in the future.
So I see Costco had some nice regular bulb shaped LED lights, replaced the CFL with the LED and notice 2 odd things, the LED doesn’t buzz throught the entire dimming curve (like the CFL), mainly from about 90% until about 50/60%, then not again until about 30% on down.
The second and more concerning issue is that when I turn off the lamp module, the LED bulb does not completely turn off, it looks like it’s at about 2-4% brightness. Only way to fully get it off is to actually turn off the physical switch on the lamp itself.
I swapped the CFL back in and it turns off as normal so it’s something specific with the LED bulb.
Anyone seen this before and know cause and easy fix until I replace the X10 lamp module itself?
