We do need someone to remove the tube, @rsim ?
This topic as a banner needs an edit. it says āmessage me directlyā but doesnāt include your name or the thread name. It says āwe need 3 drivesā and then says āwe have 2 of 4 drivers now.ā
The storage location is Science World, yes? Why would more than two trucks be efficient?
One at each location, and third in transit waiting for the first two to get our of the way.
In any case⦠Iāve driven them before for VHS, I can do it again. I donāt think I can make it to Penske at 7am.
Hi, Dan.
For clarification, the location is NOT Science World, but rather Science Worldās offsite storage facility near Powell St. + Commercial.
We donāt need 3 trucks. Technically we only need one. It would probably be good to rotate out the drivers periodically since itās going to be a long day.
Weāre going to need most of everyone at VHS loading everything else onto pallets. Unloading generally goes much quicker than loading from my experience.
[quote=āiMakeRobots, post:22, topic:914ā]
[/quote]I wasnāt aware that banners didnāt display who posted the thread. I will update that.
[/quote]It says āat least 3 driversā. Four is better.
The storage location is Science World, yes? Why would more than two trucks be efficient?One at each location, and third in transit waiting for the first two to get our of the way.
[/quote]Itās actually a warehouse on Powell, but yes, I agree that too many trucks isnāt efficient. The drivers are so that we can run the one truck in shifts, with no breaks throughout the day.
Someone suggested two trucks, but Iām not convinced thatās necessary, either. I expect that the loading the truck at VHS will be the big bottleneck, and every other portion wonāt take as long.
For everyone:
We still need drivers that can do a morning shift!
You do not need a commercial license, you just need to be comfortable(ish) driving a big truck.
Both of the current drivers need to be at work before 9, and are not able to get back to VHS before 4pm!
Thatās a lot of wasted time.
Iām in, can try to drive all day.
Great!
Thanks, Tom. See you at 7 tomorrow?
One more driver during the day would be ideal
The laser cutter has its own wheels btw.
Ah yes, the laser tube had slipped my mind - thanks for the reminder Tom! Iāll try to be down to remove it tonight, to make sure itās ready to go tomorrow.
Ack.
Lets leave the tube out of the truck. Iāll take it home for safe keeping.
How is the Vending Machine to be moved? It isnāt on a pallet yet.
If weāre going to build the pallets for the heavy equipment, weāll need tools to build them like circular saws, claw hammers, etc.
Weāll also need nails that can hold together; the ones that weāve pulled out of the walls are badly bent and wonāt serve.
So far Iāve heard of one pallet jack available at the Science World storage location. Can we get the one we borrowed before to the Bunker?
Vending machine is not our property, not our problem as far as Iām
concerned.
Vending machine is awesome, and we should make efforts to move it for whoever owns it.
Iāll ask facilities in a min if I can toss a few pallets into my truck tonight.
I can call in sick tomorrow if needed.
I can grab pallets form work, they are excited to get rid of them. Shoulda asked earlier.
So Iāll be at VHS with a truck around 8am, who else will be there? @JohnC, at what time can we start moving stuff into storage?
Iāll be at VHS around 7-730. We absolutely need a pallet jack for the load-side. Can you see if you can rent one with the truck? If not, I can try and go buy one tomorrow sometime; but if we can rent/borrow one, thatād be better.
Thanks David, will be good to work with you again.
This is my intention, whether or not more turn up.
Should I bring my nail gun, nails and saw so you can build frames for the heavy equipment between loads?
Yes. yes yes yes yes yes.
That would be much better than breaking out the palatized tools of VHS. We can deconstruct some scrap pallets to get the thin wood for the bottom of pallets, and use 2x4 for the rest of the construction. We can make some damn strong pallets that way.
There appears to be a circular saw there, but bringing a spare would definitely be great (in case the one we have is busted).
Also, does anyone have any slings / etc that we could use to lift equipment with the engine hoist? The engine hoist only has a hook on it.
