Maintenance on the Drill Press
So VHS has a good drill press right beside the laser cutter. Unfortunately, the adjusting rack which raises and lowers the platform was badly bent. So I spent a few hours carefully bending it straight and reattaching it. Here’s what it looks like now:
Although the handle is missing, it does not take a great deal of force to raise and lower the platform.
  1. Loosen the bolt (#1) on the back of the platform
  2. Lift the platform (#2)with your hand
  3. Turn the knob (#3) in the desired direction of travel with your other hand
  4. Tighten the bolt (#1) to hold the platform in position.
Do not put a Vice Grip on the knob (#3) as a handle; you will destroy the shaft!
Also, the table should not be shifted left to right; move the work on the plate instead!
I also noticed that the drive pulleys were misaligned, and the belt is pretty chewed up. Note how much higher the rightmost pulley is:
After consulting with more experienced machinists, the belt is unusable and should be removed immediately. As a result, the drill press is out of order until a replacement belt is acquired.
The belt required is:
M-24 0503 46
I have put an Out of Order sign on the drill press.
Willing to chip in if the belt is expensive
Ok, belt was cheap, it’s on there now.
Drill press should be good to go.
thanks for taking care of that!
You rawk. Thanks for doing that.
Awesome, thank you!
Thank you! Keeping our tools in peak condition is a noble endeavour; thank you!
