I’m cleaning off my workbench. These are parts for which I have no planned projects. Maybe they’re useful to you?
All this stuff is either completely unused, or lightly used by me for testing.
If you want a bunch of stuff, then prices are very much negotiable!
Lorawan nodes
Lorawan mapper node
$35 CAD
In the tupperware is an older Rasbperry Pi with SD card. The Pi has this GPS & Lorawan hat. The Pi is currently configured to send its current GPS coordinates over Lorawan to TTN. See this other thread for more information.
Adafruit RFM95W Lorawan Node
$20 CAD
This can be connected to a microcontroller to send stuff over lorawan.
Flow Meters
These can measure the rate of liquid flow. They send pulses to a microcontroller. You count the pulses to know how much liquid has flowed.
3/4" NPT
$15 CAD (2 available)
Product Info
1/2" NPT
$7.00 CAD (3 available)
Product Info
Pi Case
$5 (1 available)
Product Info
LCD Character Displays
16 columns, 2 rows of characters. Easy to drive from Arduinos and such.
$2 CAD (4 available)
LCD Character Displays “I2C Backpacks”
These solder directly to the character displays, and let you drive them with 4 wires instead of 7 wires using the I2C protocol. Also very easy to use with Arduino.
$1 CAD (SOLD OUT)
Splashproof cases
88x55x33mm
$2 CAD (3 available)
Waterproof White LED strips
24V, brite white, 5m in a roll
$10 CAD (1 available)
Limit Switches
Spring loaded limit switches
$2 CAD each, 3 available (2 with rollers, 1 springy).
Temperature Sensors
1m long - $2 (5 available)
3m long - $3 (1 available)
