One thing to note - Avrdude (arduino gui downloader) applies a reset to run the bootloader just prior to download so you need a mechanism to reset the chip. To use the serial lines for programming we either need to wire up a reset RC circuit from the DTR pin on the usb serial cable or add a reset button.
I grabbed the bag this afternoon and will figure out what we haven then order the restā¦
Thanks Tom
Thanks @packetbob. It might be worth socketing the display to make diagnosis easier. I can remove the display from my proto if you donāt have the time.
Argh, damn it. Those pins are only on the 32 pin package. Looks like we need a new pcb run or white wires. Damn. Will try to get onto it this weekā¦
I wonder if the input impedance of the input pins is high enough to not affect the output pins if I just connect PD0/1 directly to the display pins without cutting the ADC6/7 tracesā¦
I think this should work.
