There is no group buy running at the moment for parts and I donāt have the resources to run one unfortunately. I hope to add the display to my proto for a final verify soon.
I think there are - am passing them on in block of nine so if I am out, someone will have some spares. The cost for 9 is $1.65, hence my reluctance to split them any further.
I was waiting on confirmation from @TomKeddie that the BOM we currently have works on the boards we have⦠If you want to take on the group buy that will help⦠Iāll probably have 12 or so spare displays to sell also so if the amount of kits requested is under that number we should be goodā¦
Yep, Iām still in for this. Itās tough for me to get to the hackspace for the next while so Iād prefer to wait until everything is together to grab it.
Ok, this project is not dead, just not at the top of my list.
Seems I have an issue with missing rows & cols in my proto, will have to hand to @packetbob for debug. This is going to suck a little since the micro is under the display. We might want to make a test jig - pogo pins perhaps?
OKā¦
Iām going to put in an order to Digikey in order to get the parts to do a test build
If you want in then let me know, but realize that until I do the build there is a slight chance Iām off on one of the parts. YMMV and no backsies. You also must have the PCB ( @TomKeddie may have some left) and a 8x8 LED module.
The parts are split into two groups. The first set (Basic Build) will give you the basic display and may be all you want if you just want a graphics ot text to be displayed). The second set are the additional parts you need to the real time clock if you want it to keep accurate time.
I have included a Right Angle header for the ICSP (In Circuit Serial Programming) as this will also provide a nicer way to power the board but you can do as you please. Note that @TomKeddie has designed the board with pads for the serial port so you can use these to use the normal Arduino style serial port programming if you donāt have a ICSP device but you will need to attach wires to these to make use of them.
Again Iāve not yet put together one of these so Iām not 100% sure these parts are correct. You may want to wait till I have one workingā¦
Anyways Iāll put the order in probably Wednesdayā¦
I also think I have 10 of the LED displays extra so if you are interested Iāll sell them for $3.50 eachā¦
Iām also not sure of a decent battery pack for these. I was thinking of using a Adafruit booster/Charger to get the 5V out of a single Lipo (mebbe a Blackberry battery)ā¦
I also will take 9x of everything just like @wander
I will take 9x of these too, but I donāt want to take them all instead if other people want some so 3 for sure and if no one else wants them i will take the rest.
I will leave a set for you without 3528 caps out back where the toaster oven was. Iām including all my spare caps as I donāt have time to go through them, there will be something you can use in there. The caps are on the p/s so you can use any value, I used 0.1uF for the 0805, have included a strip of these - the vhs part collection has a reel I think.
There might be some header at vhs you guys can use or it might be cheaper to buy a long one and cut it up. A third possibility would be a pogo pin jig for no soldering.
