I will be making a leather journal book with zipper closure.
But I need to make a wood-block first that’s 1" thick with grooves around the perimeter.
So I’m thinking of gluing multiple 1/8" thick layers of wood
Apologies if this seems basic question but I have not worked with wood laser cutting before. I just like a little advice on what KIND I should use and WHERE can I purchase them?
Thank you!
Ed
Having done layered glue-ups like this, I recommend some alignment pin holes, even if just attached to outrigger support that you cut off after glueup. Good luck!
Also, if you prefer solid wood, consider cutting one template in the laser cutter then using a follower template bit on the router.
