I’m interested in laser etching some logos into wood and would like to spray a layer of Plasti Dip (spray on rubber coating) which I could then peel off later. I found an msds for this product and was hoping a someone from the LCC could check it out and see if it would be ok.
Hey Janet, thanks for the suggestion, I have tried painters tape as well as transfer tape but because the wood I am using has alot of imperfections and cracks, the tape doesn’t cover all the little crevices and therefore after I etch and then paint over the design, the paint seeps under the tape where it is not smooth and the tape doesn’t stick to.
