Laser Material Approval Request: Yupo Synthetic Paper
Can the laser cutter committee review Yupo Synthetic Paper for addition to the approved laser cutter materials list.
Yupo Material Information
Safety and Cutting Notes
  • Polypropylene is a non-halogenated plastic. It does not release chlorine or other corrosive gases when cut.
  • The main risks are melting and smoke, which are manageable with standard ventilation and cleaning.
  • Regular maintenance (lens and bed cleaning) is sufficient—no special procedures required.
Online User Experience
Glowforge user have discussed cutting Yupo successfully: → Yupo cuts cleanly with proper speed and ventilation, though edges can melt if the laser dwell is too high.
Some links to threads
Hey Mark,
Have you considered cutting Yupo on the cricut or vinyl cutter? Would that serve the same purpose without requiring combustion? Results may be better also.
Yes. Looking into this as well.
