Laser cutter reorientation - are there any of you who need it?
Hi guys!
I realized there might be some members who are trained on the laser cutter but who have not yet been oriented with the access control system that has been in place since we’ve been at the Cook St. location.
For more information see here: https://talk.vanhack.ca/t/laser-reorientation/1874
If you have been laser trained, but don’t know what laser.vanhack.ca is, then post it down here and I’ll get you guys re-oriented! There is no charge for this, just want to enable you all to cut with lazor beams.
Logan
I’m up for re-orientation. I need a refresher. Thanks Logan!
Awesome!
I could definitely use a re-orientation, but I’ll contact you to set up a time once I have a project to work on.
If you’re keeping a list of people who would like to be reoriented but have no idea when they might get to the space, I should put my name on it. If you’re setting up sessions or something like that, you can safely ignore me.
@bruce I was mostly using this thread to see if there were any people who need re-orienting. Now that I see there are a few of you, I’m happy to set up a session. I’ll post up something soon.
I have taken tutorial at makerlabs and would like to get acquainted with the system at VHS.
@alchemistletoe The reorientation is really just to bring members who have already done training up to date with our access control system. Typically this is just 5 minutes.
It is probably best that you go through our laser training session instead of a reorientation. In this class we go through all the quirks of the machine, basic rules regarding safety for you, the people around you and the space. We also cover how to use the software (which is quirky in itself). I’ll be running a class April 13th.
There is one spot left:
Hi Logan, that would be awesome! I know I saw the laser.vanhack.ca login, but am not sure I remember how to use it so could use the refresher. Let me know when would work best and I’ll be there :slight_smile:
Thanks!
Andrew
I too am in need of some re-orientation on the laser cutter procedures and would like to hear about any opportunities for a refresher.
Thanks,
Aaron
@AaronB Ahh, thanks for reviving this thread. I totally dropped the ball about organizing a refresher class.
I am planning on being down at the space on Wednesday evening. Would that work for anyone?
I have a prior commitment that evening. I hope some other folks can make it
Reminder, I’ll be down at the space this evening to run anyone through a refresher. Please let me know if you are coming.
