On December 22, 2016, I used the laser cutter to cut out an Inkle Loom.
Cutting Result
What’s an inkle loom?
For those that have never heard of this, it is a one-sided loom that is used to weave narrow bands. The bands can be used for belts, sashes, bookmarks, lanyards, and even guitar straps.
Here is what one commercial version of the loom looks like:
https://www.ashford.co.nz/media/com_hikashop/upload/inkles_web_1420851095.jpg
Side note: an inkle loom can also be used for tablet or card-weaving, which allows one to make really intricate patterns on narrow bands.
The design I made is based on a “rustic inkle loom” I saw on ebay.
Design stage
I opened an image in Inkscape and traced around the edges to create the outer edge of the loom. This was a lot of trial and error because I had not used Inkscape very much at this point, and wasn’t quite sure how to draw the lines. Thank goodness for youtube videos!
I saved my new file and then added in the holes for the pegs. I worked in inches, because I’m still more comfortable with Imperial measures. I set up the grid for 1/4-inch squares, and added 1/2-inch diameter holes. (After I finished the design, I switched to Metric, because the laser cutter software uses millimeters.)
I abandoned this design at one point to try something fancier. I spent a lot of time creating a completely different loom, but then came to my senses and decided to start with something simple. In between the starting point and the actual cutting, I acquired a lot of knowledge.
Thanks to discussions on Slack and on the forum, I learned what areas I needed to tweak to get my design in the right format to laser cut. The design and layout workshop by @miststlkr was also very helpful. I think I had already figured out that I needed to remove the fill and to make sure that I had narrow lines for cutting, but the workshop was a great reminder.
Cutting stage
I did my laser cutting training on the 22nd (thank you @Lukeo! ). I had previously converted my design to DXF, but I chose the wrong conversion option in Inkscape. (Tip: Use the spline option, not the other one.) Since I had downloaded my SVG file as well, it was easy to save as DXF again and get cutting.
I’m so glad that the lasercad software had options for cutting inside objects first and the outline last! That definitely minimized my setup time before I could start cutting.
I cut two copies of the loom because it needs to be at least 1/2-inch (12-13mm) thick. I was cutting 6mm birch. I didn’t need to cut two base pieces though. I’ll find some use for the leftover piece. (Maybe recut it into Christmas ornaments or something else!)
Next stage
Now that I have the main part of the loom, I need to get some pegs.
I suppose I could learn how to use the lathe and turn blocks of wood into round pegs. ![]()
Or maybe I could just purchase the appropriate dowels from Home Depot and save some time.
I’ll worry about that after Christmas.
