In this picture tehre’s a black strapping that keeps the wires and air hose out of the way of moving parts.
Anyone know what is the material used in the strap? I need a similar solution for a CNC robot I’m building. cable chain is not a viable option at this time.
straight along either axis (~1m, 45 degrees off axis)
Finding something that will flex correctly and not flop onto the table is
tricky.
Worst case is I redesign for cable chain.
Someone suggested tent poles in an X above the machine and let the
umbilical hang down. I imagine it gently - accidentally - wrapping around
the head like a boa constrictor.
The black material is just extruded acrylic and I made and broke three of them before I finally tossed that design and used energy chain. If you were going to go that route I would suggest you use polycarbonate or something chewier like hdpe.
