Intro to FreeCAD workshop March 26th and 28th
I’ve been playing with FreeCAD for almost a month now, and I’ve started to get to the point where I am able to model more complex objects pretty easily. I thought I’d put together a little intro workshop to help get people up and running and get past the fairly steep learning curve.
Topics covered:
  • Basic part modelling workflow / terminology.
  • Parameters.
  • Building things with multiple bodies that reference each other.
We probably won’t go into the assembly workflow (for making interconnected moving parts) since I haven’t done any of that yet.
  • The workshop is open to anybody, members and non-members alike. Some CAD experience is strongly recommended, but not required.
  • Capacity: ~8 people
  • Duration: 1-2 hours - I’ll have something around an hour of prepared material, and then I will stick around for another hour to chat/problem solve.
  • Bring a laptop with FreeCAD 1.0 installed so you can follow along / try stuff
  • Cost: Free, as in CAD
Friday March 28th, 1-3pm - Main table @ VHS
  • Yes I am attending!
  • I would like to attend but that date doesn’t work for me!
0 voters
If it gets over filled, or there’s lots of interest from people who can’t attend this date, I can run another session.
I’m interested but probably not available that day, and also usually only free in the evenings.
i’d love a fusion 360 iteration of this class one day too. Just throwing that out there in the world if someone’s interested.
Lots of interest!
Adding another slot next wednesday evening - please undo your vote in the poll above if you’re coming to this one instead!
Assuming this goes well, I will do this again in a few months, so if you can’t make either - fear not!
  • I am attending: Wednesday March 26th, 2025 - 6-8pm
0 voters
I could host a beginners one! I actually started in freeCAD recently, and then switched to fusion 360. I felt about 1000x more productive in 360 :cry: (which I didn’t want to happen because, open source)
Interested, but sad that I spent the last month or so crawling up the broken-glass part of the Freecad learning curve by myself already…
Would like to figure out Assemblies but no luck so far.
Anyone used VarSets vs Spreadsheets much?
I managed to use a spreadsheet config table to drive a parametric variable part , but it required following a youtube video and doing weird stuff in Just the Right Way, so couldn’t do it again w/o rewatching that video.
“Save Often”!
I’ve tried varsets and spreadsheets, and spreadsheets seemed glitchy and changes wouldn’t always show up immediately. VarSets seem to work great 10/10 would use again.
I tried doing a tentacle bit using varsets and then again w/ spreadsheets.
I found varsets really painful because the UI is half baked - the only way to rename / set the data type is to delete and recreate, and the only way to edit the mouseover info string is via the python interface.
I gave up on trying to use subshape binders to make an assembly of variants - couldn’t get them to keep their positions - when the master body recomputes they all pop back to it’s pos.
First workshop is tonight, 6-8pm
Bring a laptop with FreeCAD 1.0 installed, and if you’ve got a project you want to build there’s no better way to cement new knowledge than to start using it immediately!
Looking forward to seeing some of y’all tonight!
Workshop #2 is on for today, 1-3pm. Looking forward to seeing y’all!
Great session Cory. Thanks for putting it together and for building a real world non-trivial model we could follow along with.
