Hello,
I have a few photographs to convert to dxf.
I tried the following:
(1) Opened in Inkscape and saved it as both .svg and .dxf file (Doesn’t work)
(2) Imported the Inkscape .svg file in Autodesk Fusion 360 (Error message: Bad file: No or missing information and doesn’t display anything from the photo).
You will need to convert the imported image into vector paths in order to export it as a dxf.
Inkscape has a tool to do this conversion, but there are different types and settings depending on what you are trying to do. The Trace Bitmap tool is under the Path menu.
