I’m trying to fix several oil heaters whose one/off rocker switch is broken. I took it apart and the part that needs replacement is a 4-pole rocker switch, included the schematics below:
nobody around here seems to carry this part - I checked a few electronics shops on main.
However the switch doesn’t use the 4th Pole - 2A on schematics (it has been removed before the heater was assembled it seems), i.e. only 3 wires are connected. 1 black wire goes to 1A, and 2 blue wires go to 3B and 4B. It’s also an illuminated switch, so I suppose the black wire is there just to drive the led.
So the question is - can I use a 3-pole rocker switch instead (those are in stock)? for example this one:
Here is the full spec for the 3 pole switch.
So do you think I’d connect here the black wire to (3) and the blue ones similar to the original 4-pole switch? i.e. I’d remap:
4poles => 3poles
1A => 3
3B => 2
4B => 1
Could someone please validate that my re-mapping is correct? It’d be simple to remap with a normal switch but I have never dealt with one that uses a led, hence the confusion.
Thank you for your help.
