Hey Everyone,
I’ve been messing around with electric skateboards recently and I’d like to show off my new board.
This was my first board: Electric Street Skate | Hackaday.io
This was rev1 of the board:
The specs at the time were:
- 4x Ligo Batteries
- 2000W dual hub motors (1000 watts each)
- Ebay Dual electric speed controller and 2.4ghz remote.
The problem I was having with that setup was that it was drawing too much current for the batteries, and the batteries would cutout when accelerating at full throttle causing the board to surge making it unridable.
The problem was that each Ligo battery is rated to do 10Amp at 36v and the 2000 watt motors at 36v means it’s going to draw 55.55Amps, which is more than the 40amps the four ligo batteries can provide.
To see if I could combat the problem I found the largest capacitors I could find and strapped them on the board. This helped my surging problem but only a little bit and the board was still unrideable.
And unfortunately I could not configure the electric speed controllers to limit the amount of current.
Here is where Revision two comes in:
The specs for revision two are:
- 8x Ligo Batteries
- 1x 2.4ghz 2ch reciever and remote
- 2x Enertion FOCBOXes (aka Vesc-X)
This thing is really friggin’ fast. I had to dial it down by like 50% just to make it ridable.
It’s just slightly faster than a bicyclist when it comes to accelerating, and slightly faster when it comes to cruising speed. Unless there is an incline, then the board just screams past anyone on a bike.
With 8 ligo batteries each at 2.7Ah at 36v I’m looking at a total of 777.6Wh. Estimated range is about 40km.
The braking feels really good, and I’ll have datalogging via bluetooth once my bluetooth modules show up. The electric speed controllers are opensource and there is a lot of community support around them. We are even doing a group build on these here: [Group buy] vESC Open Source Brushless Motor Driver - #2 by Jarrett
I’m pretty content with how it rides right now. The next project is to make it more aesthetically pleasing.
