DSO Nano v3
SKU 109990013
Pocket-size open source 32bit digital storage oscilloscope
With 2.8" color TFT LCD
Waveform storage and playback
6 triggering modes
Built-in Signal Generator
They’re… OK.
They’re pretty slow, at 200 kHz, it’s not good enough for a some protocols.
It misses it’s own trigger at times, it’s interface is a bit clunky.
But it IS useful to have at home to see things that are going fast.
I can lend you mine for a bit if you wanna try.
FYI…
If you are referring to WS2811/12 etc RGB leds modules then be aware that the common speeds for these are 400 kHz and 800 kHz so a scope that maxes out at 200 kHz may not work for you…
I just picked up a DSO203 (aka DSO Quad) for the office, as we needed a battery powered scope, and it’s very nice for the price! There’s community firmware (Wildcat) that adds a ton of functionality over the stock firmware also.
I tried a google search on USBEE and they have recently gone out of business…which makes me wonder if any units being sold at this point might be the unofficial QA rejects (as happens from time to time)…
I think they most likely went out of business due to Chinese fakes like the one above.
http://www.ee101.com/download.htm “If you purchased a USBee pod after January 1, 2016, it is a counterfeit device and the below downloads will not work on your device. You will need to go to the seller for support.”
