I need two of each to try something. Does Home Depot carries anything that small?
Try your closest Fastenal
Home Depot and Canadian Tire should both carry M5’s. I’ve even seen some
M3’s at some Canadian Tires.
It probably depends on the particular store, and I also find its good to
take a known M5 nut/bolt for testing/comparison. People are always putting
the wrong nuts and bolts back in the bins.
Pacific Fasteners has a really good selection of them, I think the minimum cash order is $5 but you can mix and match any quantity so you can buy 2 of each.
I usually walk over to Brafasco on Terminal. Close to the hack space and friendly.
