Does anyone have an older cintiq power supply I can borrow to check on the state of a couple of drawing tablets. They both have screen issues which I’d like to work on (I’m thinking the caps are going) but they have no power supplies and I don’t want to invest in one off ebay until I know I can fix the screen issues.
based on my quicky research it appears to be a 12VDC power supply that uses 4 pins perhaps for current capacity as the specs say it draws 6A…
you could try opening it up to determine polarity and see if the 4 pins are joined together inside…
i’m thinking that 2 of the pins are each connected in parallel for the 12VDC supply… If you confirm this and figure out the polarity you should be able to connect any power supply as long as it can source 5A (based on what the makes specs call for)…
