Hi!
Figured I’d share my evening project with you.
We had some basic (LED) lights up in our tree this year and at dinner time, I figured I could use an Arduino and some addressable LEDs that I had lying around to bling it up a little!
First I had to figure out what kind of LEDs these were and after a bit of research I found out that they were WS2801s. (5 volt, but with separate clock and data lines!) I quickly created a project in PlatformIO and got to work. Luckily, this was supported by the NeoPixelBus library.
After a few iterations, I got the thing up and running and this was the result:
This is the resulting code:
#include <NeoPixelBus.h>
#define NUM_LEDS 50
#define MAX_SPARK_INTERVAL 25
#define MAX_BALL_INTERVAL 25
const uint8_t DataPin = 2;
const uint8_t ClockPin = 3;
#define MAX_COLOR_SATURATION 128
NeoPixelBus<NeoRgbFeature, NeoWs2801Method> strip(NUM_LEDS, ClockPin, DataPin);
RgbColor green(0, MAX_COLOR_SATURATION, 0);
int balls[NUM_LEDS];
int sparks[NUM_LEDS];
uint32_t loop_counter = 0;
void setup()
Serial.begin(115200);
while (!Serial)
; // wait for serial attach
Serial.println();
Serial.println("Initializing...");
Serial.flush();
// this resets all the neopixels to an off state
strip.Begin();
strip.Show();
Serial.println();
Serial.println("Running...");
void loop()
// First fill it out with green
for (uint16_t i = 0; i < NUM_LEDS; i++)
strip.SetPixelColor(i, green);
// Fade the balls
for (int b = 0; b < NUM_LEDS; b++)
if (balls[b] > 0)
balls[b]--;
// Sanity check
if (balls[b] < 0)
balls[b] = 0;
// Fade the sparks
for (int s = 0; s < NUM_LEDS; s++)
if (sparks[s] > 0)
sparks[s] -= 5;
// Sanity check
if (sparks[s] < 0)
sparks[s] = 0;
// If we have a sufficiently random interval, create a new spark
if (loop_counter % random(MAX_SPARK_INTERVAL) == 0)
int l = random(NUM_LEDS);
sparks[l] = MAX_COLOR_SATURATION;
Serial.println("Sparked: " + String(l));
// If we have a sufficiently random interval, create a new "ball"
if (loop_counter % random(MAX_BALL_INTERVAL) == 0)
balls[l] = MAX_COLOR_SATURATION;
Serial.println("Balled: " + String(l));
// Update the balls
if (balls[b] > 0)
strip.SetPixelColor(b, RgbColor(balls[b], 0, 0));
// Update the sparks
if (sparks[s] > 0)
strip.SetPixelColor(s, RgbColor(sparks[s], sparks[s], sparks[s]));
strip.Show();
delay(125);
loop_counter++;
