"Battery Operated Closet Lights" from the e-waste shelves
Hey, I just moved to Vancouver so I needed some under cabinet lighting for the kitchen. Imagine my delight when I saw Battery Operated Closet Lights on the e-waste shelf, with batteries just beside them! Little did I know this was going to be a misadventure in circuit hacking.
I installed them but the problem was, they only mostly sorta worked during the night. During daytime, even though the kitchen is a bit dim, the motion sensor didn’t trigger at all, so we wanted more light and didn’t get it.
Searching for “BR0020A1” didn’t turn up much, I heard the e-waste pile is Amazon returns, and even searching there didn’t find it. But it did turn up this pdf manual: https://m.media-amazon.com/images/I/B1TopJT8eXL.pdf Alas, there’s no way to adjust the sensor.
So, I guess the universe was telling me to take them apart.
It’s an IR sensor + microcontroller. Nothing crazy.
IR sensor part number is S23-S330Y. Pretty hard to find docs for it, the mfg is cagey and requires you to contact them (which went unanswered): S23-S330Y mini SMD AD PIR sensor-HJP Sensor | Gas Sensor manufacturer | Pyroelectric Infrared Sensor Supplier But a friend (from Montreal hackerspace foulab.org) managed to find the datasheet in Chinese actually: https://www.nysenba.com/static/upload/file/20251216/1765863194995099.pdf
Waveform is pretty funky, some kind of custom framing followed by PWM-coded bits:
Trouble was, when the IR sensor is in full light, the signal goes completely silent. Hmm what to do what to do. I tried to cover it with black electrical tape, still silent. Hm, weird.
Then I shifted my attention to D1 in the circuit. What could that be? The LED never turns on. Oh wait! What if it’s used as a light sensor to suppress the IR sensor during high light conditions?
And that was it. After putting a tiny patch of black electrical tape on D1, the lights work well, even in daylight, in our kitchen!
I spoke to someone last Tuesday, just before the battle bots event, who also grabbed some of these lights for their closet, and wasn’t happy with their sensor. I think his name was Bill (or Bob maybe?) and he wanted to know if I ever found a fix. He was the participant wearing the cowboy hat during the bot battle. If anyone knows his handle on here, could you please tag him?
Happy tinkering!
Fantastic hack. Thank you for hacking and posting. Welcome to Vancouver!
Hello it is I, the weirdo with the hat
Cool! Well there you go, add a little tape and see if the lights work better for you. Would love to hear if it works.
So I finally got around to modding the light, and it worked great! Thanks for hacking this, I probably would have recycled them if you didn’t figure out the fix!
