It is possible to buy flex cable replacements from some phones off eBay and
similar. The rarer your phone, the slimmer your chances, however. Open your
phone up, and if you’re lucky, it’s just a cable that’s been pulled from
the connector.
An option for getting your data off your phone could be to use a USB OTG
adapter and hook up a standard USB keyboard to it. I think that will work
for the lockscreen.
I know that flex cables are sometimes welded to circuit boards using conductive thermoplastic glue that can be re-melted and re-adhered with a temp controlled soldering iron. I did this to fix an electronic scale once. It’s doable, but not really easy … for something like a cellphone I wouldn’t hold out a lot of hope …
Little update: I was at least able to use a USB OTG cable to plug it into the keyboard, so at least I can now access the data. (Many thanks to Tom for this… although I’m not sure what your handle is! )
Trying to purchase a USB OTG right now… I know this sounds pretty lame, but I’m struggling to figure out what exact “Type” of micro- USB the DROID MAXX has so that I can purchase the correct USB OTG.
I guess it’s a Micro USB 2.0 but some sites are saying it’s a “Type B” while others allude to it being a “Type C”
Would this perhaps be the correct purchase? (It says it takes a Micro USB 2.0 )
