Want to start playing with addressable LEDs but don’t feel comfortable with programming an Arduino or ???
Always wanted to solder something but scared to try?
Need some animated LEDs for your cosplay project?
Want an easy to build project for your child?
Then this workshop may be for you. It will include a small easy to put together Wi-Fi enabled ESP8266 based LED controller that runs WLED. Also included is a 1 meter length of WS2812 addressable LEDs and a power supply (no case or mounting hardware is included)
The workshop will include basic information on using addressable LEDS and the various ways to control them. We will then assemble the kits and get you controlling your LEDs.
You will need a Wi-Fi enabled device (laptop or smart phone) to access your WLED controller…
As for the dates I will try to accommodate the people interested
It won’t be till January (second week) and option could be a Wednesday evening or a Sat/Sunday morning (or both if needed)
The kit does require soldering (we will use the soldering equipment at the Space) and I think it’s suitable as a first soldering kit for kids (YMMV)…
Get carried away and your house can look like this:
You don’t need any experience and it’s a pretty easy way to learn to solder…
The kit is reasonably easy and I have put together a build manual that you can check out:
If the LEDs are addressable it may work but may be overkill…
The 4.5V supply of the batteries may not be enough for the ESP-01 8266 module
The ESP-01 module draws a few hundred mA so may drain the AAA batteries pretty quickly
You may be better just using a Arduino Nano to drive the LEDs
If anyone wants to attend Bob’s awesome workshop but would like to learn to solder beforehand or just want a refresher pease pm me and I will get you going with the VHS blinky badge and the how-to-solder comic. The kit is 5bux donation to VHS and takes an hour or less to solder.
