Status of the metal bandsaw
Does anyone know if this is set up at the moment? Has anyone used it recently?
Thanks
Yep it should be working.
I used the green one a month or two ago. Worked fine.
Awesome, thanks!
Unless I missed that there are 2 bandsaws, I changed the blade over to a wood blade about a week ago. You’ll want to change the blade back to a metal one.
The blades are on the lowest shelf to the right as you enter the shop area in a plastic shopping bag.
https://vanhack.ca/doku.php?id=tool:horizontal_bandsaws
Last time I saw it being used was during @rsim’s lathe training, at the time it was drifting to one side, causing an angled cut, so it may need some tweaking.
