[Fixed] Laser cutter is out of focus
Laser focus is out again 25 Dec 17:56
Not sure if this is the correct
/only place to notify
Should be able to drop by tomorrow some time to check it out.
Thanks - Left front starts OK then beam gets to 3mm wide as it gets further
from the origin.
I don’t think I will be back but want thank you guys for the opportunity to
have worked with the space for the last several years.
I certainly will keep n touch.
F
Laser is all up and running again. Lenses were filthy from all the smoke and the filters for the fan have been changed. So should running and cutting a lot nicer now.
Thanks, Luke
Thanks Luke - always appreciate the laser guys doing maintenance
This topic was automatically closed after 60 minutes. New replies are no longer allowed.
