Hey all. What I am trying to design is essentially a tackle box where opening one side will force the other side to open: So when I open A, B will open as well; so the two red dots are linked in some way that they move opposite eachother either both to the inside or the outside. I am thinking a scissor mechanism between those points is what I want to connect the two? Is there a better way?
I think toma wins the cookie… still don’t know what the hell it’s called, but that should do what I had in mind. As usual, I was over-complicating it.
Pretty sure it is not that simple: I don’t think @toma’s will move. @Daniel_DeGagne gear idea should work, though that may not be the look you’re going for.
Same here… If I know the name I can look it up but my memory is crap… And looking up “that thing where two sides move mirror images” really doesn’t work so well
Thanks to all for the ideas/sites. I definitely don’t mind using gears.
