Manual lathe training
Hi, I wonder if I could be trained to use the lathe.
I need to remove a thin layer of a rod (8.8mm ->8.3 mm) so that it could fit a linear ball bearing. The material of the rod is steel. I also would like to learn how to drill holes in the center of the rod.
@rsim @Gear105
Thank you in advance for helping
Emerson
Hi,
Thank yo Emerson, I would love to join in as well.
Thanks,
RK
Hello, @Emerson @Rebel_without_Clause
Unfortunately I am unable to train anyone on the lathe for the foreseeable future.
Wondering where the four jaw chuck for the lathe is, currently only a three jaw is installed
Should be on the lathe base in the plastic yellow bag.
Hi,
Looking for lathe training as well!
Thanks,
Stefan
Thank you Stefan, I am looking for the manual lathe training as well.
Thanks,
RK
I’d definitely be up for this too.
Hugh
@Emerson @Stefan @Rebel_without_Clause @hughl87 I can run a training session on Sunday (July 9th) from 9am-2pm (it might finish up an hour or so earlier, depending on how things go - but leave the full 5 hours open as it is often necessary). Please let me know if you can attend.
Hi Richard, thank you so much for your time. Yes, I would like to attend. See you on Sunday.
Count me in! Thank you very much Richard!
Thank you Richard!
I would love to attend on Sunday (July 9th).
Thanks,
RK
Yeah that works for me. Thanks
Hi Richard, just checking we’re still going ahead tomorrow?
Hugh
@rsim
Yep! See you all then. Just a heads up that you’ll have to remove any jewelry for the training (and whenever using the lathe),
@Emerson @Stefan @Rebel_without_Clause @hughl87 - I’m running a bit behind sorry; I’ll be about 20 mins late! See you all shortly.
Great workshop!
Thank you Richard!
Thank you Richard! Excellent training!
Thanks @rsim, very helpful class.
It looks like someone has used the exact same machine for metal spinning just with a different cross slide setup
Someones also tried it on a basic wood lathe
