This is the kind of things my pcb will be able to do.
I’ve sent v1.0 to oshpark, will take a few weeks. I ended up with a constant current source on the back, cost could be as low as $2 and it lets you do pwm of each digit.
Clearance on the mounting holes is too tight, will likely need to shrink them to 2.5mm in next rev.
I’ve put pads on the back for both side to side connection and SMD pin header mounting.
The constant current source is the same schematic as the femtobuck.
One quirk is that there are up to six leds required on the back. These are needed to bring the short segments up to 3 leds and thus balance the current evenly across all segments. People can likely cover them with some black goop if needed.
So I grabbed some leds at the MMC event last night and put one onto a power supply just now. As you might expect they are really bright. Even at 10mA it feels like you are looking at an arc welder. At 5mA they’re bearable so I’ll design my sign for 5mA.
I suspect that better results will be seen using pwm on the CC supply or using a diffuser.
PCBs have not arrived yet but they should be here any day.
My next PCB will be for a working lamp I think. Will probably use the whole 10x10 pcb with a mount hole in the centre.
If anyone wants to finish/fork an Upverter design, too, I half laid out a panel, here:
Would a bench/shop light be a good use for these?
Could be but these are all warm white, personally I prefer something cold as a work light. There’s also the thermal thing, kinda needs to be an Aluminium PCB.
Yes those LEDs will fail very quickly if not kept cool
I know from experience
What voltage are you driving them with?
Something running at 110V like this would be neat.
or this one would be more likely circuit but in the floodlight form factor. This one is scary because he boosts the mains!
Hey I did a co-op at cooledge a few years back! Cool tech!
I’ve published the files at vhs-pcbs/led-segment-display at master · vhs/vhs-pcbs · GitHub
This still a work in progress
- need to test power supply
- need to add an indicator to show the top of the display
I’ve finished testing my project and it works well. Final code and pcb designs are at GitHub - TomKeddie/prj-led-segment-display
If there is enough interest we can share a dirtypcbs panel with lots of these boards.
Definitely interested!
Could you conceive these being used to make an electronic name badge – like, have someone’s name on it as a wearable? I / my team spend a bunch of time on tradefloors and conferences so “name in lights” could be a good conversation starter.
