Laser cutter panel
Plastic guard plate on control panel fell off. I stuck it back on with double sided tape on the metal l brackets
I drilled and tapped the case so that two thumbscrews can actually fasten it in place. Not going anywhere now.
Incidentally, today the laser wasn’t working because someone had fiddled with this power switch. A reminder to everyone to not touch this panel. If you do by accident, contact the LCC.
