I want to put an AEAT-6600-T16 chip on a breakout board - basically with some protective diodes, maybe a status LED, some mounting holes, and a right angle JST connector. From there I can write the code and do the testing to make it go.
Please: How would you suggest I get this chip mounted? I have neither the time nor the facilities to do it myself. Is there a 3rd party you recommend? I’d want to order these in batches of 10-20pc (unless there’s a more convenient price break).
There are also generic TSSOP breakout boards available for a few $. You won’t be able to place other components on it, but for some initial breadboard testing they can be quite useful. I got similar magnetic encoder chip working like that once.
Seeedstudio also does do pcb assembly as well. Up on another forum I know a user uses them (or at least used to) to produce some boards. It was my impression that the costs to do so, can be greatly reduced if you use parts from their standard parts list.
