I’m going to Windsor Plywood Wednesday morning, to pick up 2.5’x2.5’ sheets of 3mm and 6mm Baltic Birch Ply (classic 5x5 sheets cut in 4 to fit nicely on the laser bed).
6mm sheets are $9
3mm sheets are $6
If you’re interested in some, let me know by Tuesday. I can always take last minute requests but they don’t have much stock.
Haven’t seen this size before. they have something super thin, but I think it’s thinner than that, for model making I suppose. It’s at least 3 or 4 times the cost of the 3mm.
You can call them to confirm. Also if not 3mm or 6mm, I’d have to take the whole sheet (so 4 smaller ones)
Birch Aircraft Plywood » Windsor Plywood® if they have it in stock I’d love whatever is the largest size 1.5mm for a reasonable price, say under $50 Thanks! If they don’t have stock, or you’re not able to get it for me, it’s not a problem at all.
The aircraft plywood is 3-ply and 0.8mm thick. It is quite expensive. The last time I bought some for laser engraving business cards was over a year ago and it was about $75 for a 4x4 foot sheet. Lee Valley sells it in 2x2 foot sheets for about $35.
